Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
I suspect that my (CMOS) battery in my K7S5A is going; I've had Windows XP
freeze solid roughly once a day for the last several days. The CPU Fan
Speed, System Temp, and CPU Temp all seem reasonable so I'm guessing it's
the battery.
I'd like to go out and buy the replacement without first opening the case
but I can't find anything in the manual for the motherboard that says what
battery to use. Can someone tell me what battery I need or where to look for
the answer. I've tried googling and asking a friend with the same
motherboard but I have three different answers so far so I don't know what
to believe any more.
Rhino
rhino1 AT sympatico DOT ca
"There are two ways of constructing a software design. One way is to make it
so simple that there are obviously no deficiencies. And the other way is to
make it so complicated that there are no obvious deficiencies." - C.A.R.
Hoare
the battery.
Rhino
Hoare
