[SOLVED] Corsair H100i RGB Platinum not detected
Jan 19, 2021
5
Hi,
I'm currently trying to get my computer to "see" my Corsair AIO. I've tried to change the AIO USB position on my motherboard (now connected directly to my commander pro). I can't seem to see the device on either my device manager or ICUE. I've also updated my bios to the latest version with no luck.
Motherboard - ROG STRIX Z490-F.
Anyone got any ideas to fix this? This means that I am not able to alter the aio fan settings or the RGB for that device. Weirdly, everything else is being picked up fine by ICUE (motherboard, ram, gpu & commander pro). ICUE has also been uninstalled/updated etc with no luck.
Cheers!
you should contact Corsair.
there's a good chance that starting over with a fresh OS install,
loading latest motherboard & chipset drivers,
and then doing a fresh install of iCUE with all devices attached
would fix the issue though.
i had similar issue with a set of their crappy RGB fans and their Lighting Node.
took quite a few restarts to make contact with iCUE and would constantly lose contact and default to static speed & rainbow modes.
only a fresh install as mentioned above fixed the issue.
