Question Corsair H100x 0rpm Pump
Jan 29, 2024
7
Hello people I'm in need of some help! Recently bought the Corsair H100x Elite cooler. After installing it all and checking the rmp of everything in the bios I saw the pump is at 0rpm I've tried looking to see if I have connected something wrong but as it came with no instructions it's rather hard for my smooth brain to work out. Any help or advice would be appreciated . I have one cable from the cooler in my CPU header on the mobo and the other in pump header. still no rpm or rgb..I feel dumb that I can't work it out it seems simple enough. I know I must have done something wrong but I'm not sure what lol. Thanks for any replies.
if these are aRGB fans there will be two cables leading away for them;
one for fan RPM, a PWM 4pin cable that should connect to the CPU_FAN header.
and one for LEDs, a 3pin cable that would lead to an aRGB header.
then a 3rd cable for the pump, another 4pin cable that would connect to a ***_PUMP header.
is this cooler not designed that way?
include the motherboard make/model + other system specs.
this cooling unit was purchased new or second hand?
Mobo
MSI MPG b550 gaming plus
Cpu
Ryzen 5 5600x
Ram
Corsair VENGEANCE RGB PRO DDR4 32GB 3600MHz
GPU
AMD radeon 5700xt
PSU
Corsair RM750
CPU cooler
Corsair H100x RGB elite
2 cables from the fans and 2 cables from the block itself.
Cooler was bought brand new.
I switched the 3 pin cable from the CPU fan header to the Pump header and I'm now getting rpm on the pump in the bios.. sorry if I sound dumb but does something "need" to be connected to the cpu fan header? My fans on the cooler itself are working (connected to mobo SYS_FAN ports
