[SOLVED] Corsair ll210 fans
Dowell71
Commendable
Sep 14, 2019
57
So i need to know some stuff
im a newbie to internal connecters and rgb fans and stuff so pls help
So, im planning to buy the ll120 rgb corsair fans Multipack. My mobo is a MSI A320M PRO-E, my problem, is that if the ll120 fans can connect with this mobo without systemfan internal connectors, but instead using the lightning node pro with it and the rgb hub, because this mobo doesnt have one i think.
appreciate it if u answer
To make the fans RGB work all you need is 2 sata power cables from your PSU and one USB header from your motherboard then you simple connect the fans rgb cable to the hub headers. To make the fans spin you will need to simple connect them to fan headers on your motherboard like any fan would do.
This video may help you more:
View: https://www.youtube.com/watch?v=1Vow1nUprgc
thats the problem, idk if i have fan headers. I dont see any text that says fan_heaser or sys_fan....
  • 1 x 4-pin system fan connector (+ one for the cpu fan)
Your motherboard have only one header for fan. You either have to buy a fan controller (https://www.amazon.com/DEEPCOOL-FH-10-Integrated-Occupying-Motherboard/dp/B07DDC27BD/ref=sxin_3_ac_d_rm?ac_md=0-0-ZmFuIGNvbnRyb2xsZXI=-ac_d_rm&keywords=fan+controller&pd_rd_i=B077YHLDSP&pd_rd_r=ab4e982d-6965-4c26-924a-30c3fd6bf7b5&pd_rd_w=rIy8z&pd_rd_wg=9m2qV&pf_rd_p=d29bc9bc-49e2-46b8-bc05-387917c341ec&pf_rd_r=K7MVY8JKWEFRRCFJ99WE&qid=1568893548&s=gateway&th=1 ) or buy something like this: https://www.amazon.com/ModTek-4-Pin...+pin+to+molex&qid=1568893464&s=gateway&sr=8-5 but with this options your fan will run at 100% speed and you wont be able to controll them.
