Ok so I did a bit of research and I found that lower CAS Latency is better, as well as memory timings. I looked at the Corsair Vengeance 8GB, it has a CAS latency of 9 and 9-9-9-24 timings. The 16GB Vengeance RAM had a CAS latency of 10 and 10-10-10-27 timings. So which one should I get? It doesn't really matter what size RAM I get, which one would I be able to squeeze more performance out of? Since the 16 GB has higher CAS latency and timings, will it still be better or worse than the 8GB kit?
