I've just built a new PC based on
The system runs rock solid at the stock speeds of 2133, but when I set to 3200 in the bios using XMP, I get a couple of hours or so, then the system hangs.
The mouse responds, but the applications and windows are unresponsive. Task Manager doesnt come up with ctrl-alt-del either
Here is my RAM:
I also ran memtest, which came back with 0 errors. So I think the memory is technically fine, but for some reason has issues with XMP on this hardware combination?
It also looks like a lot of people on the forums seem to comment on issues Corsair Vengance has with Ryzen? Should I just cut my losses and get different RAM?
I have seen some memory from Corsair, basically the same model as the one I bought, being "Ryzen optmimised" whatever that means. Does some memory simply not like being overclocked?
The JEDEC rating for the RAM seems to say it can support 3200 (as opposed to needing XMP), but I'm struggling to work out which bios options to change.
I think this is the correct readout for my config?
![](/proxy.php?image=https%3A%2F%2Fi.ibb.co%2F5K3FQ7p%2Ffile.png&hash=e94bc793fff31852a4e5167c58c5a49f)
I guess my question is, do you think this memory can run at 3200 in my system, XMP or otherwise?
- 5600X
- MSI B550 Tomahawk
- 1060 6GB SC (From old system)
- 2x 8GB Corsair Vengeance LPX 16GB - CMK16GX4M2B32
Here is my RAM:
