corsair vs cooler Master
waleeda
72
hey guys i,m looking to buy a new pc case for my build with a i5 7500 8gb ram 450w psu and gtx 1060 3gb with 2 fans 1tb hdd,so what will be the best case from (corsair carbide 100r silent edition vs corsair spec 01 vs coolere master n400) i also want less noise and airflow so what will be best from these as all are of the same price for 55$ in my country thanks....
the 100r comes with one basic corsair fan, good enough and silent enough
the other, not sure if comes with 2
the buttons usually means that the fans are not controlled by the mainboard, so you use the button for those moments you need the fan to spin faster or turn off the fans completely to make the system run quieter
i don't like the spec 01, not exactly a pretty case honestly
the 100r is nice and not that big
this cooler master?
http://www.coolermaster.com/case/mid-tower/n400/
i would buy it just because it has 4 usb ports in the front, the 100r has only 2
the window in the 100r is a bit bigger than the one on the n400
i think you chose two very nice serious cases with big windows on the left panel, hard decision!
but which one has better fans as 2 fans are included with both cm n400 and corsair carbide 100r silent edition but i,ve found one big advantage of carbide 100r silent is that it also has fan controller button ?
