CPU at 100%... with no applications running
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
My computer is acting up.. right after i finish starting up, before I even
launch an application, the cursor will show a flickering hour glass (like
it's processing something), however nothing is running. And when I do try to
launch an application (something as simple as IE) it takes forever to load. I
clicked "control-alt-delete" to see my task bar -- it shows no tasks being
performed, but on the performance tab it shows CPU at 100%. I thought maybe I
had a virus, so I did a scan using Trend Micro PC-cillin, but no viruses were
detected. I'm at a loss... I just bought this computer 5 months ago, and it's
already giving my headaches.
Help please... thanks!
Click on the Processes tab in Task Manager to see what process is consuming
your CPU - it may not read 100%, but it should be a large percentage. Once
you've determined which process is causing it, it should be a simple matter
to find a fix.
- John
Download and run Process explorer
http://www.sysinternals.com/Utilities/ProcessExplorer.html
Much better than the task manager
Double clicking on a process will let you view it's image and where to
start.
http://www.albinoblacksheep.com/flash/bunny.php
In news:F606F435-A125-4C34-93F7-A14298414DAB@microsoft.com,
rjg1130 <rjg1130@discussions.microsoft.com> typed:
> before I
> even launch an application, the cursor will show a flickering
> hour
> glass (like it's processing something), however nothing is
> running.
> And when I do try to launch an application (something as simple
> as
> IE) it takes forever to load. I clicked "control-alt-delete" to
> see
> my task bar -- it shows no tasks being performed, but on the
> performance tab it shows CPU at 100%. I thought maybe I had a
> virus,
> were
> ago,
> and it's already giving my headaches.
You may not have a virus, but you may have spyware running. Which
anti-spyware programs do you use and do you keep them current?
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
i get this problem too every so often, when i do a process check. Its the
process System thats taking up all the CPU... and this happens when i leave
the computer sitting idle. When im working on it, this doesn't happen as
often. Also, done a virus check, there are no viruses detected. I run a
PC-cillin antivirus, but i also did a similar check using the antivirus
applications avaliable from Mcfee
"rjg1130" <rjg1130@discussions.microsoft.com> wrote in message
news:F606F435-A125-4C34-93F7-A14298414DAB@microsoft.com...
to
load. I
maybe I
were
it's
I am having the same problem with CPU usage at 100%. I believe this is the
aftermath of the Zotob worm.
In my case, CPU usage at 100% occurs sporadically when the following apps
are running: screen saver, Internet Explorer 6, Zone Alarm, event viewer,
DX diagnostic tool, Windows Media Player and others that I have not detected
yet.
The effect of the worm can be stopped by restarting the computer, however,
after running for a while, the problem returns. On the other hand, my
computer refuse to shutdown that made me think that the authors of the Zotob
worm knew that the worm can be made temporarily benign by shutting down the
computer.
I am anticipating a breakdown of one of my hardwares. It could be my video
card this time.
Beside event error 407, I am now getting event error 1000 which I labeled as
"The user is a moron error."
According to CNET news, Microsoft has no comment on these kind of problems.
Orinello
"Orin Oríg" <lusterlux@earthlink.net> wrote in message
news:zaXXe.1744$q1.984@newsread3.news.atl.earthlink.net...
>> even
> to
> load. I
>> being
> maybe I
> were
> it's
> the
> detected
> yet.
> Zotob
> the
> computer.
> video
> card this time.
> as
> problems.
> Orinello
Same exact problem here!
The only way to get around it for awhile is to restart, but as mentioned
above it returns.
MVP's to the rescuce! PLEASE!
|>>> even
|>> to
|>> load. I
|>>> being
|>> maybe I
|>> were
|>> it's
|>> the
|>> detected
|>> yet.
|>> Zotob
|>> the
|>> computer.
|>> video
|>> card this time.
|>> as
|>> problems.
|>> Orinello
Finally some honesty, very few people will admit to the "The user is a
moron error."
|>above it returns.
In Task Manager make sure that the user of the CPU is not System Idle as
when this is 99% it means that actual processes running are only 1%.
Viruses are only part of security. What internet security (firewall)
programme are you
using?
What are you doing with regard to removing spyware?
You need to always have up to date virus definitions. A free anti-virus
programme:
http://free.grisoft.com/doc/2/lng/us/tpl/v5
Also the Microsoft Anti Spyware Beta is considerably better than it was
at first:
http://www.microsoft.com/athome/security/spyware/default.mspx
Hope this helps.
Gerry
FCA
Using invalid email address
Stourport, Worcs, England
Enquire, plan and execute.
Please tell the newsgroup how any
suggested solution worked for you.
http://dts-l.org/goodpost.htm
> even
> (like
> try to
> load. I
> being
> maybe I
> viruses were
> and it's
What anti-virus programme is installed and are virus definitions up to
date?
The link which follows gives access to a Zotob removal tool:
http://securityresponse.symantec.com/avcenter/venc/data/w32.zotob.removal.tool.html
programme are you using?
programme:
at first:
Hope this helps.
Gerry
FCA
>> even
>> (like
>> try
> to
> load. I
>> being
> maybe I
>> viruses
> were
>> and
> it's
> is the
> apps
> viewer,
> detected
> yet.
> however,
> Zotob
> down the
> computer.
> video
> card this time.
> labeled as
> problems.
> Orinello
"Bummer" <Bummer@discussions.microsoft.com> wrote in message
news:5171F62B-2A1E-4AA8-879B-9331B23012E8@microsoft.com...
> leave
When I get this problem here the culprit is usually EXPLORER.EXE
"paul" <paul@nowhere.com> wrote in message
news:ubZXe.5862$9a2.1889@trnddc04...
>> leave
I had previously run Spybot S&D, AdAware, and Norton AV
Just ran MS AntiSpy, and it found a severe threat the others didn't
Let's see if this solves the problem...
