CPU bottleneck and resolution got me confused. need help.
cody4721
127
Hey forum
I have an old system with the following specs :
Q6600@2.6 Ghz (motherboard limited)
Asrock g31m-vs2
4gb ddr2 ram (at dual channel)
Corsair cx430
HD 4850 1GB
Screen 1366x768 (18.5 inch)
Now i want to give this system to my brother for playing games mainly newer titles like the witcher 3 , gta 5 bf3 , and some old ones and maybe just maybe fallout 4.
Now money is really tight here as i spent a huge chunk on my own new rig ( :p) . He is mainly limited by the gpu , its dx10 and most new games need dx11.
So upon searching some forums around i found out that the best card for the given specs and resolution would be the maxwell gtx750ti 2gb.
Upon reading the forums i came upon a repeated phrase "bottleneck" repeatedly , but the users on the forum mainly wanted to play on 1080p resolutions.
My querry is will the cpu really bottleneck the 750ti at that resolution ?
And some good explanation about bottleneck would be really appreciated , i am really confused at this point . what would bottleneck what and where?
Thanks you and please be a bit patient with me with my doubts
you will get slightly less fps then the gpu would produce with say a top of the line cpu that does not bottleneck it at all. however i am not able to tell you if you will bottleneck the gpu it ran about the same in the old optiplex as my best computer.
cody4721
127
But how does a cpu bottleneck a gpu ? Say if i get bottleneck by cpu does that mean i will get lower than usual fps or i will get decent fps but just not waht the card is supposed to pump out?
CDdude55
Performance would be decreased, so it could mean that a game is playable but you could be getting better performance if a certain part of the system was upgraded. If i'm running a 980 ti with a Celeron, that lower performing CPU is going to provide a bottleneck where the system might still run the game decently, but the 980 ti doesn't have room to really stretch out.
