Hello,
I am planning to build a new CPU. My basic needs are web surfing, watching movies, little gaming and other casual work.
I am from India and my budget is around 300$(15000 INR).
I already have a DVD writer, HDD, monitor, keyboard and a mouse.
I am looking for the components inside the cabinet.
I am confused with the following combinations,
AMD 2.6 GHz A6 3650 Processor or AMD 3 GHz A8 3870K Processor or AMD FX4100 Processor. I do not plan to buy a GPU so would require good inbuilt GPU.
Will this mobo be compatible with this?
Gigabyte A55M-DS2. Is there a better alternative?
Things I have decided.
SMPS Corsair CX430v2.
NZXT Gamma Cabinet.
Corsair Vengeance 4GB DDR3
The NZXT Cabinet comes with 1 fan, The city where I live is pretty hot and summers are really hot. Temperatures go upto 47ºC. It supports upto 6 fans, should I be using additional fans for extra cooling?
Thanks a lot
NZXT Gamma Cabinet.
Thanks a lot
