CPU COOLER and CASE Questions
mentathf
7
Greetings!
I have the following system specs and want to find a good cpu cooler and case. i want to spend about $100 on the case and $100 on the cooler. What are your thoughts on the CORSAIR Cooling Hydro Series. Keep in mind i just want something nice and cool and i DO NOT plan on Overclocking.
For whatever reason i have my heart set on this CORSAIR Cooling Hydro Series. As far as a case goes. Since i have video cards in Crossfire i find that the Mid tower isnt cutting. I want a case that will also keep things nice and cool.
I am a hardcore gamer, WoW, BF, CoD etc... so i tax a system pretty hard. I am not against a MID tower again, but would prefer a FULL, is i have to spend a little more then i can. OH and what are you takes on upgrading from DDR2 to DDR3 RAM? Is it worth it???
AMD Phenom II X4 940 Black Edition Deneb 3.0GHz
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard
OCZ Gold 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad kit Desktop Memory
2x XFX HD-487A-ZWFC Radeon HD 4870 1GB 256-bit GDDR5 in CROSSFIRE MODE
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified
COOLER MASTER Centurion Mid Tower
2x SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s RAID 0
4x WD Raptor 10k RPM 1.5 gbps RAID
Thanks much:
CORSAIR COOLER http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
jonpaul37
2,481
81
i would go with the Corsair cooler, it is a nice one for the price.
As for the Case, i would go with the Cooler Master HAF 922, it is sold as a mid-tower case but it is HUGE and bigger than some full tower cases. It is also liquid cooling friendly as well as really good cable management and definately big enough to fit 2 x 5870's. So, with this case, you will be all set.
Similar threads
