Cpu cooling
stefanjbkkr
5
Hey I'm currently waiting for my cooler master HAF X 942 and was hoping to find a 360mm CLOSED LOOP liquid cpu cooler since I have the crosair h100 was jsut hoping for a install and go plz help
Far as I know there arent any closed loop coolers that have bigger than a 240mm rad.
Gonna have to get into custom watercooling if you want that kind of stuff (which I do recommend, and the HAF-X is a good case for it).
But how will the H100 fit in the HAF X seeing that I want to fit it on the top mounting with the 2x 200mm fans will it fit?
You will probably have to remove the 200mm fans.
The case (and I think the H100 as well) should come with long screws that will pass through the fan, the mounting holes and then will screw into the radiator, holding it there. So your fans are above the "roof" of the case, with the rad under it.
