[SOLVED] CPU FAN and Motherboard
ggelli2014
27
Hi everyone,
I bought a used motherboard with the cpu already installed. One of the 4 screws securing the cpu fan to the motherboard is completely loose and there is no way to tighten it.
Could this give any problem or would the system still work?
Thanks so much.
Can you send a picture for context?
Having it screwed isn't the problem, it needs to be firmly on there with as even as possible mounting pressure.
Worst case scenario, say the backplate is broken, you can get a PLASTIC nut and PLASTIC washer, screw into that (Has to be plastic, metal would kill the board..) and do your best to not overtighten anything.
I uploaded a picture here
https://ibb.co/26vvd6V
Thank you very much.
