I leave my system plugged in (powered off), and never had static problems.
Nor have I read any articles saying to the extent.. my pc won't boot after I used a vacum.
I also remember companys selling PC vacuums:
Vacuum by 3M
You may not have noticed any static, but that doesn't mean it wasn't there. I linked to articles that mention it, and I also linked to an anti-static vacuum. I've given links and shown that what I am saying is correct. I am not saying you all should just stop doing what you are doing, but when people said I'm bs'ing and don't know what I'm talking about, then I found information to back it up. If anyone has articles or references that dispute it, I am truely interested in seeing them. Seriously, I would like to see them.
Boy are you missinformed about electrocution.
An ungrounded system is far safer than the common cetre tap system used in north america.
See, electricity requires a pathway between to differently referenced voltage points. If, in an ungrounded system, you come in contact to one conductor, you dont get a shock, because there is no reference. As you know, in NA, if you touch an ungrounded conductor, you get a zap.
I believe that, in Saudi, they normally use a 220v ungrounded system. Unfortuneatly it seems that contractors have been installing center tapped transformers, to take advantage of North American power tools, and appliances.
Um, no, I'm not misinformed about electrocution. I already explained that electricity moved between 2 different potentials. And, in NA if you touch an ungrounded conductor (what ever that means, I guess you mean uninsulated) you only get a shock if you are actually grounded yourself. i.e. if you are standing in a puddle of water on a concrete floor and you touch an uninsulated hot wire, you get a shock. OR, if you standing on a concrete floor and pick up an ungrounded metal-cased tool that has a short circuit causing the case to be hot, then you also get a shock...or you die.
If you are not grounded and you touch an uninsulated wire or a faulty ungrounded tool, you won't know about it unless you are also touching a ground with your other hand.
The reason for the grounding system in NA and probably other parts of the world is because people were dying. Look it up.
There is also something in NA called a
ground fault interupte, but it's only required to be used in outside electrical outlets, and in other selected areas inside, like the kitchen, bathroom, garages and unfinished basements. But, that's a whole other discussion.
Now, let me ask you a question. The guy above who lives in Saudi said he gets a constant shock when he touches some metal part on his machine, and it's not a static discharge but a prolonged shock. What would cause that?
