ASRock Z170 Pro4 mobo
i3-6100
Thermaltake 95W Gravity A2 CPU Cooler, 92mm 4-Pins PWM 1200~3500rpm Aluminum Extrusion CPU Cooling Fan
16 Gb DDR4 ram
PNY GeForce GTX 960 2 GB XLR8 Elite OC
Corsair CX450M PSU
Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive
Out of nowhere, I don't even believe with any updates, this build (my wife's PC that I put together) started acting up. No notable performance changes, but the CPU fan is spinning erratically, fast slow fast slow fast slow, WHIRRrrRRRRRrrrrrrRrRRRrrRRRRR... So of course I figure the stock fan it came with was acting up, perhaps the paste is old. I changed the paste, tried again. Nope. Updated drivers, for everything. Nope. Tried manually controlling the fan speed from the BIOS, it ignored me. Checked the heat on the CPU (and all other parts), and everything seems nice and cool. So, nope. So I buy a new fan, installed it half an hour ago... NOPE?!?! Still no change. When I check the logs for fan speed, its the CPU fan going up and down with speed at high rate. This occurs on startup, during idle, and for the entire time it is on, just not while sleeping or off.
I'm running out of ideas here. I've cleaned out dust, I've unplugged and replugged everything. Any ideas?
i3-6100
16 Gb DDR4 ram
Corsair CX450M PSU
