hi guys, just built a new system here and running into a few problems
its a uBTX factor case and motherboard, and i believe my problem is either with the 4 pin connector for the thermal module or with its connection on the motherboard itself, as the computer boots fine when i plug the thermal module into a 3 pin fan connector but nothing comes up on the screen when i plug it into the 4 pin connector
problem is that i need to use the 4 pin to regulate fan speed as its way too loud otherwise
any help would be greatly appreciated
thanks
thanks
