G
Guest
Guest
I just built a new system from scratch, and for some reason the CPU fan is not being detected. The power supply fan and chassis fan are detected fine. The CPU fan is spinning, so it is getting power. Here are the specs:
Asus CUSL2-C motherboard BIOS 1006
Pentium III 1 GHz retail box heatsink/fan
VisionTek GeForce3
Micron 256MB PC133 CL3
Windows 98SE
As you can see, the fan is the one supplied by Intel in their retail box CPU's. There is only one way to orient the 3 pin connector so I know its not plugged in backwards.
On a related note, are there any 3rd party fans that will snap on to the Intel 1 GHz heatsink that I could try to further diagnose this problem?
Thanks in advance!
VisionTek GeForce3
Windows 98SE
Thanks in advance!
