Question "CPU Fan speed detection error" ASUS TUF Gaming z690-plus
Sep 18, 2022
Just finished building my new PC, first time installing a AOI cpu system. No matter if I plug my fans into the AOI pump, cpu Fan, or even cpu opt BOIS says the same thing.
ASUS TUF Gaming Z690-Plus
i9-12900k
NZXT Kraken Z73
RM850x
Gigqbyte 3070 Ti 8gb
Samsung 970 Evo plus
2 x Corsair Vengeance rgb RT 16 gb 3200 MHz
Have you followed the directions shown in your user manual, and ensured each listed cable is connected to the required device?
https://www.datocms-assets.com/34299/1634239958-coolingkraken-z-digital-manual-en-pdf-2109.pdf
If you ignore the warning, does everything work as intended?
Yes I plugged in the 3 pin to both the AOI and the cpu. I also booted the windows and everything works fine, even temperature is decent when playing games, but it puts widows in safe mode.
Edit: CPU and DRAM LED's light up on the motherboard too
