Hello guys. Today I ran intro a problem that I can't seem to solve.
Specs:
I7-8700
Asrock B360M-HDV
Today when I turned on my PC I noticed my CPU fan is stuck at 1050 RPM (the stock one), if I change the configuration using the BIOS fan tunning program it simply doesn't work. Using any kind of windows program won't work either. If I put the CPU under stress it won't change its speed even if the CPU is at 90ºC. Usually when you start the PC the fan goes 100% and then it lowers its RPM to match the configuration: well, that doesn't happen anymore. I've done a clear CMOS, cleaned the pins and remove dust. I have absolutely no idea what else to do. CPU, fan, mobo and memory are just 6 months old.
Thank you guys.
Specs:
I7-8700
Asrock B360M-HDV
Thank you guys.
