ohk thx , ya my case is an i ball avonte case which i dont think will fit . its old idk wht to do. suggest me something should i buy new case? because the fan is 120mm and the cpu fan is 16cm height and case width is 7.6 i ll have a link of both.I can see from here you won't have troubles putting a 212 in there, motherboard spacing is fine, unless you are worried about the case? Go for it
ok https://www.amazon.in/iBall-Avonte-Cabinet-Black/dp/B00SFCD6HO here u goAre you able to get me a link to your case? I can't find it
ok u choose air system cooling but u must think forward isnt only cooler important...cable management, pc case with good air flow...i think u have bad pc case and buy new cooler u do nothingI have i5 3570 its overheating it cooled by stock cooler. I wanna buy a new one but idk will it fit with my mother motherboard Asus h61m-cs , I mean If I buy hyper 212 evo what if it touches ram I dont no what to do. Pls help..
[/QUOTy
oh ya thts a goood point im think to buy a new good airfow case with new cpu cooler im on very serious low budget so very good cable management and very good case is expensive and not up to my budget. but i think ill just buy a new good airflow case and a deepcool cpu cooer for best cooling what do u thinkok u choose air system cooling but u must think forward isnt only cooler important...cable management, pc case with good air flow...i think u have bad pc case and buy new cooler u do nothing
im in india my budget is around 10000 indian rupees . that point i didnt metion is i need a buy a new psu also with it because its everytime smells like burnt electric smell form an year ago so my psu also . pls tell me the best cooling cpu cooler and case on this budget with psuwhat is your budget for cpu cooler and case?
what is 115e ?that is very low budget cant cover everything...for around 115e case, psu and pc cooler...save your money its better solution
according to u how much minimum budget should i havethat is very low budget cant cover everything...for around 115e case, psu and pc cooler...save your money its better solution
amazon.inprovide me link for parts where u plan to buy i want check what u can buy in india
https://www.amazon.in/MSI-MAG-100M-...s=p_89:MSI&rnid=3837712031&s=computers&sr=1-1amazon.in
should i choose msi or deepcoolhttps://www.amazon.in/MSI-MAG-100M-Computer-Mini-ITX/dp/B07YQ724L8/ref=sr_1_1?dchild=1&fst=as😱ff&qid=1599475107&refinements=p_89:MSI&rnid=3837712031&s=computers&sr=1-1
https://www.amazon.in/Corsair-Airfl...d-search-10&pf_rd_t=BROWSE&pf_rd_i=1375346031
https://www.amazon.in/Thermaltake-V...?dchild=1&qid=1599474958&s=computers&sr=1-140
https://www.amazon.in/Deepcool-Shie...?dchild=1&qid=1599474978&s=computers&sr=1-158
i think msi is better, u dont need dvd driveshould i choose msi or deepcool
thank u so muchfor pc case fun go for this... fans are monster
https://www.amazon.in/ARCTIC-ACFAN0...=ARCTIC+P12&qid=1599476120&s=computers&sr=1-5
that is all cheapest and solid but far away from your budget///
if i buy a single arctic p12 should i keep them front of case or backfor pc case fun go for this... fans are monster
