Question CPU Heat issue
Jet
11
Hi, I'm having some really strange issue with my CPU and its temps.
I'm running an i7 5820k with a h110i gtx corsair cooler. I built this PC back in 2015 and I never had issues with the cooler, I don't remember when it started but it's been getting gradually worse. On boot it goes up to 80-90c, if left it keeps climbing.
BUT here's the strange twist, if I open my side panel and give the tubes from the cpu block a few decent wallops it drops down to 50c then slowly rises up to about 60c idle.
I thought it may be an issue with the thermal paste being old so I bought some artic mx-4 and reapplied it today. Same issue, still happening. I'm considering buying a new cooler at this point because I honestly have no idea what's happening to it. There's no strange noises coming from it either. The pump is supposedly running at 3000RPM according to iCUE, if it's turned lower the temp raises at 1c per second up to about 70c from 60.
I'd really like to try and figure out what is wrong with it, I have no issue with buying a new one since I've had it for a few years but it's really annoying me that I can't tell what's wrong with it.
*ANY* Suggestions whatsoever please hit me with them.
Here's screenshots from HWMonitor from boot, to the temp spike, to tapping on the 2 pipes and it dropping:
https://i.imgur.com/z6m9Fl9.png
EDIT: Here's a picture of CPU-Z:
https://i.imgur.com/V1kGQsJ.png
And here's a log of HWMonitor from the same as above
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.7.0
Monitoring
Mainboard Model X99A GAMING 9 ACK (MS-7882) (0x0000063D - 0x2A942BF4)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6792
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC9
LPCIO Revision ID 0x11
Config Mode I/O address 0x4E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 78 06 10 00 FF FF
20 C9 11 FF 00 00 00 40 01 00 FF C0 00 00 00 00 4B
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 10 0A 20 00 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A10
Hardware Monitors
Hardware monitor Nuvoton NCT6792
Voltage 0 0.95 Volts [0x77] (CPU VCORE)
Voltage 1 1.01 Volts [0x7E] (VIN1)
Voltage 2 3.31 Volts [0xCF] (AVCC)
Voltage 3 3.31 Volts [0xCF] (3VCC)
Voltage 4 1.00 Volts [0x7D] (VIN4)
Voltage 5 1.26 Volts [0x9D] (VIN5)
Voltage 6 1.05 Volts [0x83] (VIN6)
Voltage 7 1.10 Volts [0x89] (VIN7)
Voltage 8 0.95 Volts [0x77] (VIN8)
Voltage 9 0.67 Volts [0x54] (VIN9)
Voltage 10 1.00 Volts [0x7D] (VIN10)
Voltage 11 1.01 Volts [0x7E] (VIN11)
Voltage 12 1.05 Volts [0x83] (VIN12)
Voltage 13 0.67 Volts [0x54] (VIN13)
Voltage 14 1.25 Volts [0x9C] (VIN14)
Voltage 15 1.66 Volts [0xCF] (VIN15)
Temperature 0 28 degC (82 degF) [0x1C] (SYSTIN)
Temperature 1 34 degC (92 degF) [0x43] (CPUTIN)
Temperature 3 58 degC (136 degF) [0x3A] (TMPIN3)
Temperature 5 33 degC (91 degF) [0x21] (TMPIN5)
Temperature 6 28 degC (82 degF) [0x1C] (TMPIN6)
Temperature 8 13 degC (55 degF) [0xD] (TMPIN8)
Fan 1 1004 RPM [0x3EC] (CPUFANIN)
Fan 3 1075 RPM [0x433] (AUXFANIN1)
Hardware registers
bank 0
00 03 74 03 74 00 FF FF FF FF FF FF FF FF FF FF FF
10 03 99 03 99 03 99 03 7F 40 83 89 9C 54 54 E5 00
20 77 7E CF CF 7D 9D 83 1D FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 3E 00 FF DF 00 3F FF 2D FF FF 10 00 55 00 A3
50 05 FF FF FF FF FF FF FF C1 FF FF FF FF 03 02 FF
60 59 F0 FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 3B 00 3B 00 3B 00 3B 00 3B 00 17 80 FF
80 FF 7F 3F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 01 00
B0 00 00 00 00 00 00 27 00 04 00 00 00 6C 40 04 00
C0 FF FF FF FF FF FF FF FF FF 10 07 05 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 C0 1F E4 FF FF FF
bank 1
50 21 80 00 70 00 75 00 FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
50 03 F3 FF FF 00 00 00 FF FF 1E 13 33 09 00 FF FF
80 77 7E CF CF 7D 9D 83 D3 CD 83 89 9C 54 54 E5 00
90 1D 21 17 14 0D E5 00 27 40 3B 3B 3B 3B 3B 1F 17
A0 FF 1D FF FF FF FF 74 74 99 99 99 00 00 00 00 00
B0 FF 1F 2A 01 FF 1F 28 02 FF 1F FF 1F 00 00 FF FF
C0 00 00 03 EB 00 00 04 1D 00 00 00 00 FF FF FF FF
D0 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
F0 3B 80 00 00 3B 00 00 00 00 00 00 00 00 00 00 FF
bank 5
50 D3 CD 40 FF 00 00 00 00 00 00 00 00 00 00 00 00
bank 6
50 7F 7F 7F 7F 00 00 00 00 03 EB 00 00 04 1D 00 00
bank 7
Hardware monitor Hardware monitor ID=0x1B1C1C00
Register space WIN32 HID
Hardware monitor Display API
Hardware monitor NVIDIA NVAPI
Voltage 0 0.85 Volts [0x351] (GPU)
Power 0 6.18 pc (GPU)
Temperature 0 36 degC (96 degF) [0x24] (GPU)
Fan 0 0 RPM [0x0] (GPU #0)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 135.00 MHz [0x87] (Graphics)
Clock Speed 1 405.00 MHz [0x87] (Memory)
Processors
Number of sockets 1
Number of threads 12
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
Timers
ACPI timer 3.580 MHz
Perf timer 3.223 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 6 (max 6)
Number of threads 12 (max 12)
Name Intel Core i7 5820K
Codename Haswell-E/EP
Specification Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
Package (platform ID) Socket 2011 LGA (0x2)
CPUID 6.F.2
Extended CPUID 6.3F
Core Stepping R2
Technology 22 nm
TDP Limit 140.0 Watts
Tjmax 95.0 °C
Core Speed 3799.1 MHz
Multiplier x Bus Speed 38.0 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 100.0 MHz
Stock frequency 3300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
Microcode Revision 0x3A
L1 Data cache 6 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 6 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 15 MBytes, 20-way set associative, 64-byte line size
Max CPUID level 0000000Fh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 15 MB, 16 thread(s)
FID/VID Control yes
IBRS not supported
IBPB not supported
STIBP not supported
RDCL_NO no
IBRS_ALL not supported
Turbo Mode supported, enabled
Max non-turbo ratio 33x
Max turbo ratio 38x
Max efficiency ratio 12x
Min Power 37 Watts
O/C bins unlimited
Ratio 1 core 38x
Ratio 2 cores 38x
Ratio 3 cores 38x
Ratio 4 cores 38x
Ratio 5 cores 38x
Ratio 6 cores 38x
Ratio 7 cores 34x
Ratio 8 cores 34x
Ratio 9 cores 34x
Ratio 10 cores 34x
Ratio 11 cores 34x
Ratio 12 cores 34x
Ratio 13 cores 34x
Ratio 14 cores 34x
Ratio 15 cores 34x
Ratio 16 cores 34x
Ratio 17 cores 34x
Ratio 18 cores 34x
IA Voltage Mode Override
IA Voltage Target 1126 mV
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 358 mV
TDP Level 140.0 W @ 33x
TDP Level 140.0 W @ 30x
Temperature 0 59 degC (138 degF) (Package)
Temperature 1 53 degC (127 degF) (Core #0)
Temperature 2 53 degC (127 degF) (Core #1)
Temperature 3 56 degC (132 degF) (Core #2)
Temperature 4 53 degC (127 degF) (Core #3)
Temperature 5 52 degC (125 degF) (Core #4)
Temperature 6 49 degC (120 degF) (Core #5)
Voltage 0 1.13 Volts (IA)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.36 Volts (System Agent Offset)
Voltage 4 1.10 Volts (VID #0)
Voltage 5 1.10 Volts (VID #1)
Voltage 6 1.10 Volts (VID #2)
Voltage 7 1.10 Volts (VID #3)
Voltage 8 1.10 Volts (VID #4)
Voltage 9 1.10 Volts (VID #5)
Power 00 35.72 W (Package)
Power 01 n.a. (IA Cores)
Power 02 n.a. (Uncore)
Power 03 n.a. (DRAM)
Clock Speed 0 3799.11 MHz (Core #0)
Clock Speed 1 3799.11 MHz (Core #1)
Clock Speed 2 3799.11 MHz (Core #2)
Clock Speed 3 3799.11 MHz (Core #3)
Clock Speed 4 3799.11 MHz (Core #4)
Clock Speed 5 3799.11 MHz (Core #5)
Core 0 max ratio 38.0 (effective 38.0)
Core 1 max ratio 38.0 (effective 38.0)
Core 2 max ratio 38.0 (effective 38.0)
Core 3 max ratio 38.0 (effective 38.0)
Core 4 max ratio 38.0 (effective 38.0)
Core 5 max ratio 38.0 (effective 38.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000F 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306F2 0x00100800 0x7FFEFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x04C0003F 0x00002FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00002120
0x00000006 0x00000077 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x000037AB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x0000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000F 0x00000000 0x00000017 0x00000000 0x00000002
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3238352D 0x43204B30 0x40205550
0x80000004 0x332E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x0000302E 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x20080C3B 0xF3812100
MSR 0x00000017 0x00080000 0x00000000
MSR 0x00000035 0x00000000 0x0006000C
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x22222626 0x26262626
MSR 0x000001AE 0x22222222 0x22222222
MSR 0x000001AF 0x00000000 0x00002222
MSR 0x00000194 0x00000000 0x000E0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88180000
MSR 0x000001FC 0x00000000 0x2B000059
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00101414 0x00001FFF
MSR 0x00000610 0x0007FFF8 0x001DFFF8
MSR 0x00000611 0x00000000 0x047D379A
MSR 0x00000639 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x01280460
MSR 0x00000648 0x00000000 0x00000021
MSR 0x00000649 0x00940000 0x001E0460
MSR 0x0000064A 0x00940000 0x00000000
MSR 0x0000064B 0x00000000 0x00000000
MSR 0x0000019C 0x00000000 0x88190000
MSR 0x000001A2 0x00000000 0x005F0A00
MSR 0x00000198 0x00002323 0x00002600
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x000306F2 0x01100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x88170000
MSR 0x00000611 0x00000000 0x047D6EDF
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x000306F2 0x02100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0x047DA995
MSR 0x0000019C 0x00000000 0x881C0000
MSR 0x00000198 0x00002342 0x00002600
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x000306F2 0x03100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0x047DD983
MSR 0x0000019C 0x00000000 0x881A0000
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000306F2 0x04100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x047E068E
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x000306F2 0x05100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x047E3364
MSR 0x0000019C 0x00000000 0x88180000
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x000306F2 0x06100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x047E6155
MSR 0x0000019C 0x00000000 0x881B0000
MSR 0x00000198 0x0000231F 0x00002600
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
CPUID
0x00000001 0x000306F2 0x07100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000007
MSR 0x000001B1 0x00000000 0x88190000
MSR 0x00000611 0x00000000 0x047E8D4F
CPU Thread 8
APIC ID 8
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x000306F2 0x08100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000008
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000008
MSR 0x00000611 0x00000000 0x047EBEED
MSR 0x00000198 0x00002321 0x00002600
CPU Thread 9
APIC ID 9
Topology Processor ID 0, Core ID 4, Thread ID 1
CPUID
0x00000001 0x000306F2 0x09100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000009
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000009
MSR 0x00000611 0x00000000 0x047EEE2B
CPU Thread 10
APIC ID 10
Topology Processor ID 0, Core ID 5, Thread ID 0
CPUID
0x00000001 0x000306F2 0x0A100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000A
0x0000000B 0x00000004 0x0000000C 0x00000201 0x0000000A
MSR 0x00000611 0x00000000 0x047F1BBF
MSR 0x00000198 0x00002331 0x00002600
CPU Thread 11
APIC ID 11
Topology Processor ID 0, Core ID 5, Thread ID 1
CPUID
0x00000001 0x000306F2 0x0B100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000B
0x0000000B 0x00000004 0x0000000C 0x00000201 0x0000000B
MSR 0x00000611 0x00000000 0x047F4979
Storage
Drive 0
Name Samsung SSD 850 EVO 500GB
Revision EMT03B6Q
Serial S3PTNB0J812810W
Capacity 465.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 465.2 GBytes (37.6 percent available)
Drive 1
Name ST2000DM006-2DM164
Revision CC26
Serial Z4Z9LSZ6
Capacity 1863.0 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume e:\, 1863.0 GBytes (80.7 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x0520
USB Device Corsair RM750i High-Performance ATX Power Supply, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x1C0B
USB Device Corsair Hydro Series 7289 USB Device, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x0C07
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x800A
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x2109, product=0x3431
USB Device USB Composite Device, class=0xEF, subclass=0x02, vendor=0x03F0, product=0xE807
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x003E
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1A2C, product=0x2124
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8002
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1080200
Name NVIDIA GeForce GTX 980 Ti
Board Manufacturer GIGABYTE Technology
Revision A1
Codename GM200
Core family 0x120 (GM200)
Technology 28 nm
Memory size 6 GB
Memory type GDDR5
Memory vendor Hynix
PCI device bus 5 (0x5), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x17C8 (0x36B6)
Revision ID 0xA1
Performance Level 0
Core clock 135.0 MHz
Memory clock 405.0 MHz
Monitor 0
Model 24EA53 (LG Electronics (GoldStar))
ID GSM59AC
Serial
Manufacturing Date Week 5, Year 2012
Size 23.1 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-61 Hz
Max Pixel Clock 150 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Is this 100% the issue? Even though it says the pump is running on iCUE? It's not making any strange noises or anything. It still is under warranty but I contacted corsair about 5 days ago through a support ticket and still haven't heard anything back from them.
Squeeze both tubes coming out of either side of the pump. They should have equal pressure. While you are at it, are both tubes the same temperature? One should be noticeably cooler than the other.
The fact that you can hit it and it cools things down makes me think that the pump has an obstruction or is jamming.
It honestly sounds like the pump is working then. My only other though is that something is faulty with the contact between the IHS and the cooler. Maybe too much paste or too little? Did you make sure to clean off the old stuff?
Yup cleaned it off with the 99.9% alcohol stuff, applied paste, checked it and wasn't enough. Cleaned it off applied a bit more and it spread across it all, cleaned it and did it again with the same amount to ensure it was fully covered.
Yeah that's really weird. Double check that the screws are secure. My only guess is that something is wrong with the pump, and it is letting enough water through to maintain some pressure but not enough to keep up with the heat generated by the cpu. If you can't test it on another rig, then I would probably just RMA it if it is still under warranty.
jet,
• You have an intermittent flow problem due to a partial blockage, which is typical for a unit over three years old. Most AIO's fail well within that time frame.
Apart from the potential for a coolant leak, there are four problems common to AIO's:
(1) All AIO's will eventually fail. It’s not a question of if; it’s a question of when. Pumps can have component failures in the electronics that drive the impeller, which is a moving part that can wear out, so those which run 24/7/365 are prone to premature failure. AIO units are notorious for failures due to inferior pump quality, whereas custom loops typically use high-end pumps which have greater longevity.
(2) Coolant can slowly evaporate over time due to "permeation". However unlikely it may seem, coolant can actually dissipate directly through the tubes. This can introduce bubbles into the impeller chamber which can cause it to "cavitate", thereby reducing or interrupting coolant flow.
(3) AIO's are sealed Closed Loop Coolers (CLC), which unlike custom loops, are not designed to be disassembled for the water block and impeller to be flushed, cleaned of bio-contaminants and radiator sediments, then refilled. Bio-contaminants gradually accumulate over time and will eventually clog the water block and radiator tubes, thereby reducing flow and thermal efficiency. This is evidenced by Core temperatures that slowly increase over periods of several months to a few years.
(4) Also unlike custom loops, AIO's use dissimilar metals (aluminum radiator / copper water block). This causes galvanic corrosion which produces sediments that accumulate over time, resulting in blockages and flow problems. Even new AIO's may contain radiator sediments due to inadequate flushing after manufacturing. Experienced builders of custom loops will always thoroughly flush brand-new radiators. Flux, solder and metal fragments are typically found in the flush water when it's poured through a strainer.
For no apparent reason ... OR ... by simply installing, moving, tipping, handling or otherwise disturbing a NEW OR OLD unit, particles can become dislodged, whereupon the next power-up, the now free-floating particles can circulate into the impeller chamber and restrict or completely stop the impeller. Since the impeller is magnetically coupled to the stator (no direct shaft), the unit may "appear" that it's running while the impeller is restricted or stalled. "Hearing" the unit running or "feeling" vibration can be deceiving as it does not necessarily indicate flow, nor does Pump RPM in BIOS or various software utilities. Pump vibration is often mistaken for fan vibration which can "telegraph" throughout entire the AIO unit.
Without an actual in-line sensor, proper flow is difficult to confirm. Under normal operation, even with the CPU at 100% workload, there should be only a minimal temperature differential between the tubes. However, if one tube is hot while the other is cool, or the water block is hot while the radiator is cool, it indicates little to no flow. Surface temperatures can be verified with an infrared (IR) thermometer.
• Since your AIO is at least three years old, it's highly likely that bio-contaminants and particles from galvanic corrosion are intermittently impeding coolant flow as they circulate throughout the unit.
Fortunately, Corsair has a five year warranty, which much to their credit, they honor without difficulty. I suggest that you submit an RMA request for a warranty replacement cooler. In the interim, a backup air cooler should suffice. While your AIO remains in service, be sure that you don't leave your rig powered up or unattended when not in use.
CT :sol:
