RagedAPE Distinguished Jan 6, 2014 214 26 18,640 Sep 16, 2020 #1 Is it a safe bet to buy the 3900XT tomorrow and will it fine for 5 years gaming with a 3080. Kind regards, Ape.
GarrettL Distinguished Dec 4, 2019 2,414 640 19,990 Sep 16, 2020 #2 Do you use a 1440p or 4k monitor? At higher resolutions you don't need a high end cpu, the 3600x would produce the same framerates at 4k as a 3900x. Upvote 0 Downvote
RagedAPE Distinguished Jan 6, 2014 214 26 18,640 Sep 16, 2020 #3 I am thinking of buying a 1440p monitor like the Rog 1ms one to match it. to tell you the truth I kinda need help with a whole build. Upvote 0 Downvote
M mdd1963 Titan Jan 14, 2006 16,612 1,729 81,240 Sep 16, 2020 #4 AMD is coming out with it's next gen of CPUs in a month or so, possibly with a 5% bump in clock speeds, and a 10% jump in IPC.... Currently, the 3900X offers next to nothing over/above the 3700X, so, IMO, you'd be paying extra for unused cores/threads... I'd either wait, or get a 3600/3700... (No one can give a 5 year 'you'll be fine assurance, but, you'd 'probably be fine'....or I'll refund your money!) Upvote 0 Downvote
RagedAPE Distinguished Jan 6, 2014 214 26 18,640 Sep 16, 2020 #5 I have £2500 to build a pc from Pc specalist UK and I don't know the best bang for buck to buy for 1440p e-sports gaming. I have picked so far 3900XT 3080 Rog Strix x570-Fgaming 32Gb corsair Vengeance 3600mhz 750gold RMX Coolmaster Mastercase h500 argb 1TB firecuda 520 Corsair h100i platinum Artic mx4 extreme thermal conductivity I could sure use some help please PCSPECIALIST - Configure the AMD Am4 Gen3 PC to your ideal requirements. PCSpecialist is an award-winning manufacturer of high quality custom PCs & Laptops. Configure the AMD Am4 Gen3 PC to your ideal requirements. www.pcspecialist.co.uk Upvote 0 Downvote
