[SOLVED] CPU (i7 8700) Performing way below expectations (6th percentile)
I only have a stock cooler on the i7 8700. I had read that this particular stock cooler was bad at load, but found differing opinions online about whether it would really have an impact. I am happy to invest in a better cooler if this will help.
Yeah, the stock cooler was inadequate for the 8700. https://www.tomshardware.com/reviews/intel-core-i7-8700-cpu-review,5638.html
Getting a better cooler would allow for higher boost speeds which would increase performance. Here's a good option that won't break the bank.
https://pcpartpicker.com/product/HQW9TW/corsair-cpu-cooler-cafa70
I just ran a UserBenchmark Test of my PC to check components after installing a new GPU.
I found that my CPU is "Performing way below expectations (6th percentile)".
Appreciate any advice on how I can fix this. Is my CPU faulty?
Many thanks in advance!!!
https://www.userbenchmark.com/UserRun/23893856#PROCESSOR
It looks like your boost frequency is not getting up to what it should. The userbenchmark shows a turbo of only 3.55Ghz That is why @rgd1101 asked about power supply, CPU cooling and motherboard (VRM) cooling. Those are the kinds of things that could hurt boost clocks.
Thanks both. Here is more information:
Motherboard: ASUS PRIME Z370-A
PSU: Corsair TX650M
CPU temperatures -
Idle: around 32 celsius
Intel CPULoad Test: 75-80 celsius, peaked at 82
PSU: Corsair TX650M
CPU temperatures -
What cpu cooler are you using? Also the 8700s that scored the highest had been locked at their all thread turbo speed, which given your current temps likely isn't a good option for you.
I would not mind spending more tbh! Can you suggest any RBG cpu cooler that is decent and works with Asus Aura?
If not RBG, what about the H7?
