Greetings guys,
Today I came home to all my fans going jet-engine-ape-xxxx, nothing heavy running, just the usual stuff open, so kinda weird and no clue how long they've done it for. Rebooted and was greeted with a CPU overheating error and could only enter BIOS. Turned it off and let it cool down. But now I can't start it without it running up to 80-85˚, and it does that even when only idle in BIOS.
i7-5820k 3.3Ghz, no OC.
Asus X99-A
Corsair H60i
Pump is connected to CPU OPT and radiator fans to CPU FAN, and all looks fine to me but is apparently not.
This have worked just fine ever since I put it together, and without any changes to anything this started happening today.
Some thoughts and speculation...
- Don't think its the pump, it is apparently running, and it is cooling as I can feel a considerable different in temperature on the tubing coming from the CPU compare to going to it.
- Can it be the thermal paste? But if so, would that have degraded over time and temperature slowly rising with it? Not from normal to this over a day?
Any thoughts and inputs are more then welcome.
Thanks!
/A
<MODERATOR EDIT>
Tom's is a family friendly website.
Profanity is STRICTLY FORBIDDEN and is a BANNING OFFESNSE !
WATCH YOUR LANGUAGE !
Asus X99-A
Corsair H60i
Thanks!
/A
<MODERATOR EDIT>
