I'm experiencing an issue with my AIO where occasionally on boot, I will hear my fans working extremely hard and I see that my temps begin to rise within the 75°-90° range where upon noticing I immediately restart my pc. I notice that after doing this it's as if I can hear the pump begin to work and make water noises, which then fixes the issue.
The several times that this has occurred, a restart fixes the issue instantly and I won't experience the problem for a few days which is rather confusing. While using my PC/Gaming, my temps are all within safe ranges and I don't run into any issues.
I have gone into the BIOS and made sure that my pump is running at full speed/power as I have seen others recommend to do here that have had similar issues as mine and also that my CPU fans are running at full power as well.
Specs in reference:
MoBo - GIGABYTE Z690 UD DDR4
AIO - Lian LI GALAHAD AIO 240mm.
CPU - Intel Core i7-12700KF
Apps I use to monitor temp are HWinfo 64 and occasionaly Gigabyte Control Center.
Any help would be greatly appreciated!
Specs in reference:
