Question Cpu speed drops
Mar 16, 2020
9
I have an intel i7-7700HQ (laptop) processor with speed drops to around 1.2 GHz. Most often this happens when I play. I noticed then that the use of all components decreases. The processor is undervolted to -0,140V but when I set it to 0 the problem still exists.
alceryes
This is normal for most laptops. You can try external cooling to mitigate the downclock but it may not be enough.
These CPUs were never meant to run at full GHz speed, with load, for any length of time. Very few laptops are able to do this.. If you want full speed, most/all the time, you'll need to look at the larger, expensive gaming laptops with really good active cooling.
86zx
Upstanding
Nov 1, 2019
484
89
290
17
Put windows power plan to high performance and best to play games when plugged in. I have a msi laptop with a 7700hq in it and without undervolting it stays at 3.6ghz
Mar 16, 2020
9
Why because of the battery? Can I prevent it somehow? Can it turn off some of the technologies, e.g. speed step or speed shift?
Mar 16, 2020
9
I have a power plan set for high performance and 100% CPU power management
86zx
Upstanding
Nov 1, 2019
484
89
290
17
So cpu lowers the speed so as not to overheat?
Yes ,what is the model of laptop? I’m kinda curious if they didn’t apply enough thermal paste from the factory it shouldn’t be throttling that hard unless they shoved a 7700hq into a ultrabook. My msi ge62 isn’t very thick and it keeps the cpu around 80c fully loaded and at 3.6-3.8ghz
