Question CPU temp issues
dovokko
Commendable
Jan 25, 2018
Hi
After recently getting a new PC i have been monitoring my CPU's temp with the stock cooler it was provided with. Most notably when playing games such as Rust my CPU temp slowly creeps up into the 80 degrees Celsius. And with other high demanding games my CPU them can run up into the mid 70's to 80's. Is this anything to worry about? If so what CPU cooler would you recommend to replace my current one.
P.S. There are 3 intake fans in the front of the case and one in the back that pulls out air.
PC Specs:
CPU:Intel i7-9700F
GPU:GTX 1660TI
Memory:16GB
Power Supply: 500 watt
Motherboard:TUF-B365M-PLUS-GAMING
Hi
PC Specs:
CPU:Intel i7-9700F
GPU:GTX 1660TI
Memory:16GB
A bit high but nothing to worry about,
