My CPU and Cooler: Lian Li Galahad 240mm + 10700k
After noticing that I was running extremely high temps, such as high 80s and 90s while gaming, I decided to change the positioning of my radiator from what's labeled as "Okay" in the image, to what's labeled as "Better" in the image.
After making the change, I turned on my computer only to notice even HIGHER CPU temperatures. Upon startup the computer was running at 75-80 degrees, so I checked if the pump was mounted properly, and I reseated it just in case. I also checked if the pump and tubes were working, and they were as I felt vibration on the tubes and the pump. The pump is also shown to be running at 3300 RPM in the bios. I turned off the computer for the night thinking that maybe the coolant needs to settle or something, and this morning, I turned on the PC to check the temps. The temps upon startup were significantly lower and were about 40-45C. I then opened up FIFA 23 to test the temps under load, and before I wouldn't usually exceed 80 degrees while playing, but now the temperature suddenly shot up to 95C. I closed the game and the CPU temps slowly got lower over a span of around 5 minutes and reduced to about 45-50C. I don't know what the issue is, because the pump and tubes are running, and if the AIO failed, why did this happen so suddenly? The temps were not acting like this just one day ago. I'm going to use the warranty on the Galahad 240 and get a new one, and then see it out, but what is the problem here?
