I'm after a cpu water cooling, something like the Corsair H90 or the Antec H20 920, however I'm also looking to upgrade to a full water cooled system at a later date.
I want a modular system, so that I may extend it later, however the Corsair is a sealed unit, although I'm not sure about the Antec.
I can find suitable radiators and pipe/pipe attachements ok, but using a pump and tank will not fit. I have room for 1 slot in a 5 1/4 drive bay, I have seen drive bay reservoirs but a suitable option would be one which combine a pump and reservoir in one.
Alternatively, are there any processor block/pump combinations?
I have an AMD AM3+ socket processor
thanks
thanks
