Creative Sound Blaster X-Fi Titanium no sound
mobbdeep856
9
Hello everyone today i bought a Sound Blaster X-Fi Titanium , i uninstalled my current audio drivers,and installed it into my rig.. booted up, installed drivers off Creative website, after rebooting i get sound and everything works, but when i change a setting in the creative control panel such as.. changing between modes (Entertainment, Gaming, Audio Creation) the sound shuts completely off, only thing that fixes it is a reboot, i uninstalled all audio drivers including my motherboards driver, but still no luck help would be appreciated :bounce:
**HEADSET: SteelSeries Siberia v2**
PC:
-Intel Core i5-2500K Sandy Bridge 4.5GHz
w/ COOLER MASTER Hyper 212
-ASRock P67 EXTREME4 GEN3
-G.SKILL Ripjaws Series 4GB (2 x 2GB)
- PNY GeForce GTX 550 Ti x2 SLI
- OCZ ModXStream Pro 600W
Here's my last stab at this ok.
Otherwise you have a problem beyond my expertise.
Download DS.
http://phyxion.net/item/driver-sweeper.html
Dump everything Creative in add/remove
Run DS in safemode
Check off Creative
Analyze and clean
Reboot = normal
At this point i'd remove the soundcard
Put the card back in
What slot are you using? you might want to try another.
Download the appropriate drivers from Creative
Install as Admin
Good luck!
