Aztralis Apr 26, 2019 4 0 10 Sep 27, 2019 #1 Crucial Ballistix Sport LT 16GB DDR4 3000MHz CL16 Dual Channel Kit is compatible with my other components(530w source; gtx 1050ti 4gb oc ; motherboard a320m-pro-e ,and ryzen 3 1200 ) And Finally if all it's compatible , it's a good build?
Solution NightHawkRMX Sep 27, 2019 The PSU is the backbone of your PC. Never cheap out on it. Even though the 1050ti doesnt use tons of power, a really crappy PSU would not be ideal.
NightHawkRMX Titan Ambassador Jan 1, 2018 18,589 3,985 81,540 Sep 27, 2019 #2 All compatable. What is the exact make and model of PSU? Upvote 0 Downvote
Aztralis Apr 26, 2019 4 0 10 Sep 27, 2019 #3 NightHawkRMX said: All compatable. What is the exact make and model of PSU? Click to expand... uuuuummm , I don't really know man ) But I'm sure it's stronger enough Upvote 0 Downvote
NightHawkRMX Titan Ambassador Jan 1, 2018 18,589 3,985 81,540 Sep 27, 2019 Solution #4 The PSU is the backbone of your PC. Never cheap out on it. Even though the 1050ti doesnt use tons of power, a really crappy PSU would not be ideal. Reactions: Phillip Corcoran Upvote 0 Downvote Solution
