Custom Built Gaming PC Help
HomeGrownHeroz
114
I have recently decided to build myself a computer as my laptop is outdated and can not handle 3d software applications and games that I wish to run.
This is the first computer I have ever built and i'm obviously trying to be cautious because of this. I have had a friend to help me and I have also tried to do a bit of research myself. To find all the parts I used ebuyer.
Please look at the parts below I have chosen and let me know your views and if it will definatley all run ok.
Thanks.
AMD Phenom II X4 940 3GHz Socket AM2+ 6MB L3 Cache Retail Boxed Processor
Asus M3N-HT Deluxe/Mempipe Nforce 780a SLI Socket AM2+ onboard VGA HDMI audio ATX Motherboard
Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Kit CL5 1.8v
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache - OEM
ZOTAC GTX260 192 Core SYNERGY EDITION 896MB DDR3 Dual DVI PhysX and Cuda ready PCI-E Graphics Card
Black Mid Tower Gaming Case with Massive 14cm Front Fan - No PSU
Arctic Power 700W PSU - With PCI-E, 4x SATA, 20+4, ATX12V, 8pin +12V Connectors
What is it you would reccomend then? The main reason it may seem expensive is because of the monitor I have chosen. Given that all the parts are good quality i would assume that they would run very well. My budget is preferably between £500 - £600 but I will be willing to spend more if certain parts will benefit me in the future.
