Greetings all,
I recently purchased an ascension cyo case with accompanying hard drive racks. I'm new to nuts and bolts and 'custom' cases, so I lack even most basic info.
I've bolded the 'questions'.
Here's how I was planning to fasten the 120mm fans + hard drive racks to the case (please review and comment) - outside to inside:
* bolt - similar to "6-32 1.5 inch Black Oxide bolts w/nuts. (4 pack)" - however it seems 4mm (8/32) bolts will fit, which would be more sturdy, so I was thinking of using 4mm wide 35/40mm (1.5"/1.75") long ones instead.
- no washer (should I?)
* case side/wall - this is just (part of) the case itself
* rubber gasket for noise reduction - hopefully this will also reduce vibration led to the hard drives
* 120mm fan
- no rubber gasket (should I? would this reduce vibrations moved to hard drive rack / hard drives? Or would this simply weaken the build and perhaps increase vibrations?)
* hard drive rack
* nut
Thanks for your time
* 120mm fan
* hard drive rack
* nut
