Deepcool 240EX RGB/LED cooler and Corsair?
leftyblack
5
I'm doing a new RGB build which is mostly MSI/Corsair. The exception component is a DEEPCOOL 240EX processor cooler that I want for the look (building in a white case). Has anyone tried to control the LED on the 240EX with a Corsair Commander Pro or Lighting Node Pro? Do they play nice?
Aside: I would be fine using any other white rad instead but according to the newegg search options this is the only white rad that fits the 2066 chipset.
Thanks in advance hardware gods!
Yep, all the case fans in this build will be LL Corsair. So..much..LED! I was hoping to use a white Rad without breaking the build. Bummer that Corsair doesn't make one.
