Question Deepcool iceblade pro v2 fit in dc dukase v2?
Jan 15, 2020
Hi
I have dc dukase v2(160mm cpu height) i wana buy cpu cooler , will iceblade pro v2(161mm) fit in this case?
Will 1mm make problems?
Very limited market here i dont have lot choices
I'd recommend keeping under the case's height maximum. The manufacturer may or may not accept the return just because it didn't fit, better to be safe than sorry and lose some cash.
What's your max budget, CPU, and socket type? I can try to find another decent cooler.
Yes i know but
Very small and limited market here .
Only gammaxx s40 , twinfrost v2, cm m410p ,cm hyper 212 led ,Thermaltake Frio Silent 14 ,SilverStone Argon Tuf
And all of them very expensive here like double price .
My cpu :amd a10 6800k but iwana change it to r5 2600 or i5 9400
