DELL E5420 Thermal Problem
Greetings friends, This time, I purchased a DELL E5420 CORE i5 2520m laptop for office. In principle I know that it is an old laptop but I only need it for a couple of things, I bought it on ebay and everything is fine. But it came with a problem. The laptop turns on and does not mark any errors, but after 5 min it turns off, clearly due to overheating.
I read them friends.
- The temperature goes from 58 ° C to 100 ° C in 15 seconds. at the same time the fan speeds up disproportionately of course for the same problem.
- Without a doubt the first thing I did was change the thermal paste, clean the fan cooler, oil it, and make a diagnosis of possible failures
- I found on a physical level that everything was very original, well maintained and working as it should.
- I tried the battery alone, change the charger, change the battery, I used it without a battery and only with a charger and it is always the same result
- All this happens both in the BIOS and in windows, it has the same behavior.
