Question Desk Microphone Arme Specific Use Case
Apr 30, 2022
Hello,
I'm trying to find a cheap desk arm for my Audio Technica A2020 microphone. Currently, I'm using a stand, but it is at an awkward height where I have to put my neck at a weird angle to speak directly into it. However, The desk I use is very large (I think it's a dinner table from IKEA, but I'm not sure).
There are metal bars around the bottom perimeter of the desk that make the total thickness around the edges about 7cm. Looking around Amazon, I haven't found many desk arms that support this thickness. One I did find is here:
https://www.amazon.com/Adjustable-M...322507&sprefix=aokeo+ak-3,aps,112&sr=8-5&th=1
But, its description and images are inconsistent, and I've seen varying reviews in terms of clamp thickness. I also contacted their support, but the only thing they told me so far is that the clamp design changes on a yearly basis. But, there is another issue.
The clamp can't just attach to the desk where the metal bars are, due to it potentially being unstable. (If anyone has a mic arm, could you measure the diameter of the circular part that contacts the bottom of the desk?) Instead, it needs to have the depth to clear the metal bars and clamp down behind them. I have attached a rough diagram for better visualization of this.
I would prefer to avoid buying a separate clamp because that would unnecessarily increase the price. I already have a pop filter, shock mount, etc. lying around, so I don't need a mic arm that comes with those accessories. Any help would be very much appreciated. Thank you.
Diagram of the Edge of Desk: https://preview.redd.it/nwudptp82ow...bp&s=c29b2da3537c71d90df77e721e9b0156ff244f12
Hello,
https://www.amazon.com/Adjustable-Microphone-Suspension-Constructed-Professional/dp/B01MZ99Y67/ref=sr_1_5?crid=2ZAZJH4O4NKZS&keywords=aokeo+ak-35&qid=1651322507&sprefix=aokeo+ak-3,aps,112&sr=8-5&th=1
Why not get one like this -- https://www.amazon.com/Adjustable-Microphone-Suspension-Microphones-Management/dp/B0863HPBWX/ It has as base that a single hole through the top will permanently mount it. No clamp required.
I've looked up many solutions where you drill a hole into the desk. Although this is a decent solution, I would prefer to avoid this because I'm not 100% comfortable with a permanent application like that. Thank you for the suggestion, though.
If the bottom metal disk is narrower than the metal bar, and that metal bar is solid and flat, it should be as solid holding the mic as the actual desk surface.
Thank you for the suggestion. Do you know any reputable brands that have clamps that support being mounted horizontally in the way you described?
