I searched best I could, so my apologies if this has been asked already!
It seems the 64 3800+ has appeared in most cpu roundups on the net, and still seems to kick a significant amount of ass. The question i have is that on Pricewatch they list two versions, the AMD 64 3800+ and an AMD 64 3800+ 90nm revE, which is 50% more. Thing is the CPU roundups I've looked at from here and elsewhere dont say which one of these they are using. This is kind of important, because I would spring for the $250 one, but if its the $350 90nm revE one they are reviewing for I might as well get the X2 3800 for $400. (Speaking of which, theres no difference in motherboard requirements between a 64 and an X2 right--Sorry I've been out of the cpu loop since I bought my last computer 2 years ago.)
I do know that the one reviewed is a 2.4ghz 512k, which the old 3800+ seems to be, but both have 512k and i haven't been able to see if the revE is 2.4ghz as well, because if it is then the 3800 that was reviewed could be either. At any rate, what is the difference between them (besides core size obviously), and is it worth $100?
Thanks for your help!
