Dimension 8300 front panel USB connector location
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I bought a floppy bay card reader for my Dimension 8300. It didn't come
with instructions.
The description on the PC Club web site states that it connects to the
USB Front Panel Connector.
Where is that located? The connector is a flat, inline, 4-pin female
with what looks like a blank at one end to ensure proper pin alignment
on the motherboard connector. There is only one 4-pin male connector
that I can see on the motherboard and it has no plastic guide so I have
no idea IF it's the right connector, and if it is, which way to put it
on.
The connector in question is about an inch to the right and a half inch
down from the motherboard battery as viewed with the PCI cards to the
left.
Anyone install anything like this in a Dimension care to lend some
advice?
I only paid $10 for the card reader. I really hate to spend $50 to have
PC Club install it.
Greg Smith
smithgrowl@woh.rr.com
Remove the bird to reply via email.
"Greg Smith" <smithgrowl@woh.rr.com> wrote in message
news:MPG.1b09df4e14d08c42989685@news-server.woh.rr.com...
> with instructions.
> on.
> left.
> advice?
> PC Club install it.
> Greg Smith
Greg,
I don't know of an additional USB pinout on that mb, but that's not to say
that's not what you're seeing from those 4 pins. If you'll look closely
(which in my case would require reading glasses), there should be writing
(in white) by those pins indicating what they in fact are. The Dell website
has gotten pretty weak in providing detailed layouts of their system boards.
The primary front USB (and audio for that matter) connector can be found by
locating the 1.5' flat ribbon cable that runs to the front ("control panel")
I/O board below the hard drive cage (and to the mb as well). You might also
wish to take a flashlight and view that I/O board for pins, but I believe
the only ones that will be vacant are for an internal speaker and chassis
intrusion plug-in that the Dimension does not utilize (Optiplex does).
Post back.
Stew
In article <goWnc.99923$7a5.44287@bignews6.bellsouth.net>, stew1960
@mail.com says...
> > with instructions.
> > on.
> > left.
> > advice?
> > PC Club install it.
> > Greg Smith
> Greg,
> Post back.
> Stew
Apparently the 8300 does not have a USB connector on the motherboard. I
either have to buy a PCI USB card and add a 5 port card to my current 8
or I have to homebrew a cable from a USB extension cable by splicing it
to the card reader, run it through a hole in a PCI slot cover, and plug
it into a free USB slot in the back (outside) of the case.
Greg Smith
It didn't come
> with instructions.
connects to the
4-pin female
pin alignment
male connector
guide so I have
way to put it
> on.
and a half inch
cards to the
> left.
lend some
> advice?
spend $50 to have
> PC Club install it.
> Greg Smith
The front USB port is behind the lift up panel on the front
of the tower. The panel is round on the bottom. Just lift it
up and the USB port is facing down, under an overhang. There
is a headphone connector next to it.
In article <4YSdnXYdncznRj3dRVn-uw@comcast.com>, fkozerski@comcast.net
says...
> It didn't come
> > with instructions.
> connects to the
> 4-pin female
> pin alignment
> male connector
> guide so I have
> way to put it
> > on.
> and a half inch
> cards to the
> > left.
> lend some
> > advice?
> spend $50 to have
> > PC Club install it.
> > Greg Smith
What I meant was the *motherboard* front USB connector but apparently
there isn't one. At least not one that isn't proprietary. I'm going to
have to create a USB cable that I'll run outside through a PCI card slot
and plug it into a rear external USB port.
NOTE to Dell if you're reading...proprietary-free design be a factor in
my next PC purchase.
Greg Smith
