Dimensions and weight of 7950 graphic card+box
mostwanted_1002
11
Hello everyone,
I need the exact dimensions and weight of sapphire 7950 graphic card+box. This is the card http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006. any hints of how n wer to find out them are also most welcome :)
Do you mean the actual size (and weight) of the box the GPU is packaged in, with the product inside it? Why do you need to know that?
The details tab at Newegg (for a product) will list the physical dimensions of the product. The product page at the manufacturers website is also provided.
I know of no source that provides the "product in the box" info you seem to want.
Please clarify.
Yes I need the dimensions(lxbxh) and the weight of the box with the product and all the accessories in it. The reason is I am planning to get the card to india through my relative from US. So he asked for the details (weight and dimensions).
And both the newegg site and the product site contain the dimensions of the card and not the box.
Sorry for being unclear above.
the best you can do is a guesstimate based on a video or something. This isn't the kind of information most people care about so it would be very hard to find.
find the card on amazon...scroll down to product dimensions...
Your link doesnt work so I don't know what card you want but for example...
http://www.amazon.com/Sapphire-PCI-Express-version-Graphics-11196-10-40G/dp/B0082D58P4/ref=sr_1_1?ie=UTF8&qid=1351114490&sr=8-1&keywords=sapphire+7950
Product Dimensions: 14.8 x 4 x 9.8 inches ; 3.7 pounds
Shipping Weight: 6 pounds
those cant be card dimensions and 3.7 pounds is probably the box weight with gpu in it. Then the 6 is it package in another box with packaging and such.
