Disabling on-board sound on a K7N2 Delta-ILSR
Richard
974
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
Hi,
Sorry if this is a dumb question, but I've just bought an MSI K7N2
Delta-ILSR ready to install over the weekend and I can't see any obvious way
of turning off the on-board sound so that I can use my sound card instead.
All the motherboards I've come across before have a jumper to this.
Thanks
In article <c6bolc$b28$1@news8.svr.pol.co.uk>, no-
one@thisfreeserveaddress.com says...
> Hi,
> Thanks
Enable / Disable from Bios
d{ò_ò}b PK
"The computer can't tell you the emotional story.
It can give you the exact mathematical design,
but what's missing is the eyebrows."
Hello Richard,
The setting is in your BIOS, please read the manual that came with
your board.
If you do not have a manual, please go here
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=436
and download the latest online version in PDF format.
If you don't have a sound card better than the Audigy, then the
onboard sound is superior. If you are only using the card for the
gameport, then I can understand.
Alternatively, you can also visit MSI forums for nVidia Chipset Based
Motherboards here. http://forum.msi.com.tw/board.php?boardid=14&sid=
Good Luck!
Glenn Aka GlennVidia (Moderator at MSI forums)
GlennVidia wrote:
> Hello Richard,
> your board.
Still trying to work out why it has an auto/disabled setting for a modem
it doesn't have on-board, it took me ages to figure out why my
external modem wouldn't work. I assume they use the same BIOS for
different boards. It's a bit odd for the default setting to be auto for
a feature it doesn't have. :)
Thanks for the link. At least trying to search a computer file is easier
than the manual.
I have a Turtle Beach Santa Cruz card which I've been using for a couple
of years. For the moment I'm using the on-board sound and have to admit
it's damn good. In the future I'm looking to get a studio quality card
and I don't mean the stuff that creative labs put out. :)
Forums as well, excellent, I'll have a look.
"Richard Lane" <richard@no-spam-for-me-thank-you.co.uk> wrote in message
news:c732fi$ffi$1@newsg2.svr.pol.co.uk...
its something to do with the workings for the modem being on-board but you
need the ACR (audio/communications riser) card to actually use it. when you
plug the riser card in, the 'auto' setting picks up on it and hey
presto......
