[SOLVED] Discovered a burnt spot on Seagate 2TB Barracuda.
MakotoSGT
139
Hey guys!
So sometime back my mobo died and i decided to sell off my other parts before attempting another fresh build.
After disassembling, I discovered the drive I used for storage has a burnt spot.
Image: View: https://imgur.com/a/tAAJWvC
I don't know how old or how long ago this was caused but I'm afraid of losing m data in it, it has images and videos of family/stuff from the past 20 years. (Drive is about 4 years old)
I'm not sure if it works or not, since i dont have a working PC with me at the moment nor do I know if its safe enough or will stay safe until I can copy over my important data.
I need your opinions.
Will a PCB swap fix this if the drive never gets picked up?
Or will this thing get worse if I plug it in another PC?
Chances of usability?
It appears that the drive has sustained an overvoltage on the 5V input. This is caused by a bad PSU or incorrect wiring.
Don't do this:
Warning: do not interchange modular PSU cables:
http://www.hddoracle.com/viewtopic.php?f=56&t=2545
This is probably what happened:
TVS Diode FAQ:
http://www.hddoracle.com/viewtopic.php?f=100&t=86
A replacement PCB will require a firmware transfer (US$50):
https://www.hdd-parts.com/14012375.html
If there is no other damage, you may be able to recover your data by bridging the zero-ohm resistors and removing the 5V TVS diode. That should cost nothing.
Whatever you do, you MUST NOT damage the ROM chip. This chip contains unique "adaptive" data.
"Adaptives" -- why PCB swaps don't...
Don't do this:
TVS Diode FAQ:
"Adaptives" -- why PCB swaps don't work in modern HDDs:
http://www.hddoracle.com/viewtopic.php?f=56&t=2600&p=19090#p19090
Don't do this:
TVS Diode FAQ:
So there is hope.
I'm ready to shell out enough money for 2 drives worth if it means I can clone the entire drive onto another one, if that is possible.
However, I'll be happy enough to just recover personal data and thrash the rest.
PS: This reminds me, my MB went overvoltage on the 12v uptil 15v when it died within a few hours. PSU was thrashed after.
SO i'm guessing, that's what happened here.
