[SOLVED] Display color is with yellow tint on moments for 1, 2 seconds
vito.janevski
Commendable
Jul 12, 2018
When I work something my monitor color goes with warmer colors on moments, when I press some key it goes back to normal.
How can I fix this?
Thank you!
Vito.
Sounds like blue light filter. I had a similar issue when i had two running and causing conflicts. The screen would occasionally flash different warms of colours.
Bottom right of the windows bar there should be one called Night Light, or search for it in the windows box. Else, check settings if you have installed your own blue light filter.
