Good afternoon all,
Have had this laptop for only a few months, nothing fancy, standard Core i5 Model, 8 Gigs of Ram and it uses the onboard video processor. This issue that has been presenting itself is that after extensive use, text starts to get distorted, to the point that it is unreadable. As if it is not displaying all of the pixels in the letter, as well as making the text look larger.
Additionally the image will vibrate/shudder vertically only, never horizontally. If you do a Windows Print Screen, the image that is captured is correct, text is fine etc. Rebooting fixes the issue right away and it will work correctly for hours, but then it happens again.
Loose connection for the display, faulty display or CPU/onboard GPU issue? Any thoughts?
Thank you,
-Mark
Thank you,
-Mark
