Ok, lets try to explain this one
First off, i have my PC for 5 years now and its working perfectly fine ever since.
Yesterday i upgraded my Graphics-Card from a GTX760 to a RX5600XT.
Previously i was using DVI Connectors, but now i had to switch over to Display Port. I am using 3 Monitors and had a couple of DP-Cables somewhere.
Issue1: When Display-Port Cables are connected it seems that they are providing some power through Pin20 to the Motherboard. The PC won't turn on. If i unplug the power cable from my monitors then it works.
Ok, so i am able to turn the PC on now. Great! But now another strange thing happens:
Issue2: When shutting down the PC, the fan of my chassis keeps on as well as the CPU Fan as well as the RGB lighting on my new RX5600XT. During shutdown i again turn off the power supply for my monitors but it seems that the PSU is still active also preventing me from thurning the PC on again. Only flicking the power switch at the PSU finally turns everything off.
So right now i always do the following when shutting down:
I just ordered 3x VESA certified DP cables that have no pin 20. I hope this will solve all my issues. What do you think?
Much appreciated!
- Unplug power supply of monitors
- Flick the power switch of PSU to off
- Power on PSU
- Start PC
- Plug in power supply of monitors
Much appreciated!
