Question Displays not connecting when powering up
Mar 16, 2019
I have two displays, one connected by HDMI and one by DVI. Normally they are plugged into the graphics card. For some reason when I power up normally, I have to unplug/plug in my HDMI monitor for it to recognize, but it always happens and I don’t think it’s related to the issue. Neither screen had signal this time. Tried plugging the DVI into the mobo and still got nothing. It seems to recognize it’s been plugged in to something, but then just goes to no signal mode. I’ve also tried unplugging everything (including USBs) and booting, then plugging in the monitors, and still nothing. CPU and auxiliary fans have power so the mobo is getting power. Not sure how to address this since I can’t see the screens at all...
What are the specs for your system? Does your system also have an integrated GPU? If so, remove your GPU and then connect your display(s) to your motherboard's video connections.
Do your displays show anything now? If yes, the GPU is the likely issue.
