Do i need a wireless card for my wireless netbook
jimena
I have a wireless netbook. Currently I am using Clear - where I plug an ethernet cable into the netbook.
I would like to go wireless. What do I need to do? Simply buy a wireless router? Will I need any type of card or adapter?
Thanks,
Jimena
jimena
Thanks! - that sounds pretty simple. I keep seeing about the wireless card being the same as the router. But I guess that is referring to if your computer is not already wireless.
G
Guest
Guest
Be aware that there are different types of wireless networks. Clearwire uses WiMax technology whereas most home wireless is 802.11a/b/g/n. The 2 are not compatible.
