Hello all!
I recently upgraded to a Ryzen 9 3900x from a Ryzen 7 2700x. On my 2700x, I just used the included Wraith Prism cooler and managed to cool my CPU pretty well. So when I decided to upgrade, I figured I'd need to go with a beefier CPU cooler. However, I decided to install the 3900x with the Wraith Prism and spend a couple of days going through my normal workflow and checking temps on a regular basis just to see how it handled it. Here's how it's performing:
Idle Temps: Usually hold pretty steady at around 40-41C
Normal Usage (Watching movies, typing documents, surfing web): Mid-40s or so
Rending Video: Topped out at about 75C after about a half hour of rendering
Light Gaming: Hovered around Mid-60s-ish
Cinebench: Benchmarked for 10 minutes and it hovered in the low to mid 80s
Not really sure what kind of temps to expect. I think for what I usually do, temps look pretty good. The hardest I ever work my PC is video rendering for maybe 2-3 hours at a time, but usually not much more than that.
I was considering a better air cooler. I've been looking at a couple of them, the main one being a Dark Rock Pro 4 from Be Quiet!. My question is this: Do I really need better cooling? If I decided to go with something like the Dark Rock Pro 4, would I see any benefit? And how much could I expect it to lower my temps on average? Keep in mind that I'm not overclocking either, just running the CPU normally.
Any info or advice would be appreciated.
Thanks!
Thanks!
