[SOLVED] Do I need liquid cooling?
You don't have any viable liquid cooler options because the chassis doesn't support them. A 120mm AIO isn't going to cut it with a hyperthreaded hexa core, so you're left with air anyways.
Noctua NH-U12A: stock and overclocked conditions
Thermalright Silver Arrow T8: stock and OC
Thermalright Le Grand Macho RT: stock and OC
Thermalright Macho Direct: stock
be quiet! Dark Rock TF: stock
Noctua NH-U12S: stock
Arctic Freezer 34 eSports Duo: stock
... and so on.
You're probably trying to fit a certain theme too, so things aren't looking up...
... and so on.
Reactions: CountMike
Yeah that's exactly what I'm doing I might need to get another case I only have this one on pre-order so hopefully I can get a refund. Only other option is a small customer loop but not something I want to do tbh
If I continue with this case and setup and did go for air only do you think it could potentially overheat?
