[SOLVED] Does a HDMI 2.1 to DVI cable exist?
JQA
Nov 14, 2020
I'm looking for an HDMI 2.1 to DVI dual link cable, even an HDMI 1.3 or above is fine but I can't seem to find a product that specifies that the HDMI is 1.3 or above. I want to use my monitor at 1920x1080 120hz, according to this guide that should be enough.
Thanks for the welcome! I'm using an Asus vg248qe and I actually want to connect it to my Xbox series X, the Xbox comes with an HDMI 2.1 cable for the 120hz but my monitor doesn't support HDMI 2.1. I have my PC hooked up using the Display Port so thought I would use the spare DVI port as a mean to achieve 120hz
